Customized issues level access to specified users
shahid iqbal July 15, 2014
I want some of the users to see only those issues which are created by them.
Example - There are three users in system - A, B, C.
I want user "A" to see only those issues which he has created.
Users B and C can see all issues in the project either created by them or by somebody else.
Please help.
Thank you Nic,
I have seen this tutorial -
https://confluence.atlassian.com/display/JIRA051/Current+Reporter+Browse+Project+Permission
but i have no clue how do i edit this file - WEB-INF/classes/permission-types.xml
Nic Brough -Adaptavist-
July 15, 2014
Your best option is to use "current reporter browse permission" to let user A see their own issues, then a role in the project to allow B and C in.
Thank you Nic,
July 15, 2014
Um. You open the file in an editor, make changes, and use the save option.
I'm not sure I can help you if you don't know how to edit files on a computer.
Nic Brough (Adaptavist)
It's part of the Jira installation, as it says in the documentation.
Where do i get this file ? Once i have it i can edit it.
Thank you
July 15, 2014
As the documentation says, it's part of Jira.
shahid iqbal July 17, 2014
I hope you can tell me something which can really help me. I did read the document its nowhere mentioned how to reach to this file. Do you know where ?
Marcus Silveira
July 17, 2014
Hi Shahid,
The file should be inside your installation folder/atlassian-jira/WEB-INF/classes.
Hope this helps
Thank you Marcus,
I think thats what i wanted. I appreciate.
