I am looking at some perf issues with our JIRA instance and noticed that the fill factor is 100% on our MSSQL box.
JIRA is database agnostic - it uses a database driver to talk to the database, but it has no understanding of what the database is behind that. If you suspect fragmentation or database indexing to be issues, then you need to deal with them on a database level.
Just to clarify, since JIRA is using some bad fill factors, it's acceptable to take some aspects of DB maintenance into my own hand and add a few missing indexes, or to implement DB maintenance plans to rebuild some indexes?
Yes, although do not do it while JIRA is running.
