DONE issues not marked as 'Complete' when completing the Sprint
Niels Corver
When I click 'Complete Sprint', the 'DONE' tickets are not marked as 'Complete'. So the issues stay in the next Sprint. They should no longer be visible in the next Sprint. How do I fix this?
Thanks for the help!
2 accepted
11 votes
Alexis Robert
Hi @Niels Corver ,
this is because the DONE column needs to be the last one on the right side of the board for Jira to consider that its issues are completed in the Sprint.
Once you change this, you will be able to complete the sprint.
Let me know if this helps,
--Alexis
Pranay Pandey
January 28, 2023
Yes, it works. Thanks @Alexis Robert .
This is very interesting to know.  I think if the issue resolution is marked done then Sprint should consider it Complete.
Like # people like this
Hagen Volpers
September 11, 2023
Hi @Alexis Robert
why is it not reflecting the workflow status? I have status "done" and "obsolete", both are defined as status done in my workflows, but ending a sprint does ignore that status and only go by columns?!
How should I handle user stories that are obsolete, not implemented or whatever kind of "no result" status you prefer?
Best regards,
  Hagen
Niels Corver
It's working. Thanks a lot!
Alexis Robert
You're welcome ! don't hesitate to mark this as "Accept Answer" so that other users can find this later on :)
Have a nice day !
Jacques LEROUX
March 21, 2024
Yes it's working
Perhaps, instead of losing 2hours of time to understand this issue, Atlassian can also improve is product :
- don't let people remove the Done column from the last position
or
- only take the status of the tickets and not the position of a column
Or put a better message ....
Jeimi Herrera
Thanks, @Alexis Robert . This information was helpfully.
