I encountered a critical issue while trying to migrate a team project between Jira Cloud instances:
Current Situation:
- All projects except the newly imported one have disappeared
- Lost Premium plan access that was previously available for free
- Currently on Free plan with limited support options
Steps that led to this issue:
1. Had a team Jira account and company Jira account
2. Attempted to migrate team project to company account
3. Imported backup file to company account
4. After import, all existing projects disappeared
Questions:
1. How can I recover the lost projects?
2. What are the immediate steps I should take to minimize damage?
3. Is there a way to restore the previous state of the instance?
Any help or guidance would be greatly appreciated as this is affecting our company's operations.
Hello @Hyoeun kim and welcome to the Atlassian Community!
If there's an option to check the original instance or backup files for missing projects, it's worth doing so. Though, first, maybe it's worth contacting the support team to find out if they can help you solve your issue: https://support.atlassian.com/contact/#/
In the case of data migration, it's always better to verify backup consistency before actual migration, that can help to avoid data loss. If you're looking for a reliable backup solution, take a look at GitProtect backup for Jira Cloud: https://marketplace.atlassian.com/apps/1228719/gitprotect-io-for-jira-backup-restore-dr-data-management?hosting=cloud&tab=overview
Daria
Welcome to the community!
a. Check for Projects in Trash (Cloud Recycle Bin):
b. Verify Backup Restores:
a. Prevent Further Changes:
b. Gather Information:
c. Verify Plan Subscription:
d. Export Current Data:
CSV
or JSON
Hope this will be helpful!
