×Hi,
I am trying to import data of Issue type "Story" for follwoing fields :
Issue Type:
Issue Status:
Issue Priority:
Issue Affects Version/s:
Issue Fix Version/s:
Issue Labels:
Issue Epic Link:
Issue Epic
I am using follwoing command
jira.bat --server https://xxxxx.com/jira--user xxxx --password "xxxx" --action runFromCsv --file import.csv --propertyFile import.properties --common --continue
Vesion
Jira Version : 6.0
Cli : 3.8.0
Problem:
Data of all field imporated except the data of "Epic".
What could be the reason also there is no error is coming. i also verify import.properties file correctly.
Please help me!
KP
The default agile custom field name for epic is call "Epic Name". Also, some agile custom fields are "locked" which may prevent updates.
Thanks Bob!
So if i have to import the data of field "Epic" for issue type "Story" what i have to do.
Please help.!
-KP
Bob,
So how we can unlocked the locked field ?.
Please help .
Thanks in Advanced.
-KP
You need to map "Epic" to "Epic Name" in your properties file if you can't change your csv. See this for more info.
For unlocking fields, see https://confluence.atlassian.com/display/GHKB/How+to+unlock+a+Locked+field
Hi Bob,
I rename "Epic" with "Epic Name" please see the data of my properties file
field.IssueType = Type
field.Component = Components
field.Project = Project
field.Prioritys = Priority
field.Epic Name = Epic Name
field.Epic Link= Epic Link
field.Labels = Labels
After successfully import i am able to import data of all field except "Epic Name".
What could be the reason?
Please correct me if i am missing any step.
Thanks in Advanced
Pleae help
KP
More details from side for this issue :
Following fields are displying when i am going to create an "Story" using Jira 6.0.
-SummaryRequired
-Priority
-Due Date Select a date
-Component/s None
-Affects Version/s
-Fix Version/s
-Assignee
-Environment
-Description
-Original Estimate (eg. 3w 4d 12h)
-Remaining Estimate (eg. 3w 4d 12h)
-Attachment
-Story Points
-Epic
-Labels
-Units
-PercentDone
-DueTime
-Story Points
-Business Value
-Flagged
-Impediment
-Epic Link
KP
