I connected Java Melody to the Oracle database. I must changed configuration like below:
dbconfig.xml:
<jira-database-config>
<name>defaultDS</name>
<delegator-name>default</delegator-name>
<database-type>oracle10g</database-type>
<jndi-datasource>
<jndi-name>java:comp/env/jdbc/JiraDS</jndi-name>
</jndi-datasource>
</jira-database-config>
additional lines in <Context> in server.xml:
<Resource name="jdbc/JiraDS" auth="Container" type="javax.sql.DataSource"
url="jdbc:oracle:thin:@//YYY:1525/XXX"
driverClassName="oracle.jdbc.OracleDriver"
username="jiradbuser"
password=
minIdle="20"
maxActive="40"
maxWaitMillis="30000"
minEvictableIdleTimeMillis="60000"
timeBetweenEvictionRunsMillis="300000"
maxIdle="40"
removeAbandoned="true"
removeAbandonedTimeout="300"
and Java Melody working fine, but every settings are default, so my connection pool size is not 40, but 8. Do you have any idea why?
Wojciech Miecznikowski
Hello Wojciech Miecznikowski,
You should have to use maxTotal="40"
password=
minIdle="20"
maxTotal="40"
maxIdle="40"
anyone have any idea? I can not find correct configuration
