×To much of these date syntax errors! Several places! Please correct!
1. Choosing dates from the calender icon
I use the calender to choose dates and then Jira say it is wrong format?!
Come on! This should of course be correct dates if you choose from Jiras own calender icon!
2. The date format (e.g. Microsoft standard)
The explaining text say use "yyyy-MM-dd HH:mm" which normaly in other programs is e.g. "2018-Dec-12 12:00" (MM= Month written out in text).
But what it should have asked for; ...following format: "YYYY-MM-DD HH:mm", i.e. 2018-12-12 12:00
3. Entering date information
If you try enter date information in a Story in the "End date"-field you get many errors and difficulties if you now doing it in the rgith format, even if you choose the date from the calender icon...
Kindly make sure that format masks for dates are the same in the following options
https://confluence.atlassian.com/doc/configuring-time-and-date-formats-150144.html
https://confluence.atlassian.com/jira/changing-the-due-date-input-format-192536.html
