Default Original Estimate field to 4h using PF
Zhihua
March 8, 2021
Hi Support
I try to default the value of Original Estimate to 4h when I create the issue in the Backlog.
But the value only set to "4h" after I click the "Create" in the "Create issue" Screen.
How can we default its value to 4 in the "Create Screen"?
Danyal Iqbal
March 9, 2021
That is not possible.
Zhihua
March 9, 2021
I realise this after I spent hours on this.
Looks like manually add the value is only way right now.
Nic Brough -Adaptavist-
March 9, 2021
If you know it's going to always be 4h, you can set it with an automation instead.  If it's almost always going to be 4h, it might be acceptable to do that and then ask the people creating the issue to go back and change it on the small number of times when it's not going to be 4h
