Default Watcher to issue
Sony June 20, 2013
how to set default watcher to the all issue of particular project?
Christian Czaia [Decadis AG]
June 20, 2013
Sam Alexander
June 9, 2014
This is the first result for many Google searches on the topic. It may be better to expound on the issue within this answer.
Like # people like this
David Baboo
November 7, 2014
Say it Sam! I second your sentiment.
Like shaijujanardhanan likes this
Ayelet (888)
I third smile
Mark Sanchana
August 21, 2019
Me to!
Prateek Sharma
May 6, 2015
You can do it by adding new notification scheme and assign it to your project. In notification Scheme, you can control different notification events, notification types and whom to notify? More details can be found here
Manage Notification Scheme
Ayelet (888)
that's a great idea!
Like Iswaren Mardenalom likes this
Iswaren Mardenalom May 6, 2019
That's THEE idea. Way simple that adding script, code, plugins or anything.
Go into the notification scheme and update the notification you want.
In my case, I update "Issue updated" and added user manually with the "Single user" option. It does not add people as watch list but it will notify people anyway.
Easiest way when all management people want to be notified.
Nirosh Perera
October 16, 2020
Create default Watchers for Project which is effective automatically at the creation of each task of that project:
1. Fist have all the people added to your project by:
>> Project Settings >> People >> add users as required
2. Then add default users from the people you have added in the project:
>> Project Settings >> Automation >> Create rule (find: Right top corner) >> Select the trigger: Issue created (or you can any other trigger as required) >> Save >> click - Add component >> New Action >> Type: "Watcher" in All action search box >> select: Manage watchers - it comes after search >> Click : Add these watchers - select all the people you want to give this viewing privilege >> Save >> Click: Rule details >> Give a name to rule >> Save >> Click: Rule details >> Click: Publish rule at top right corner.
Ravi Shah March 25, 2020
Hi @Sony ,
You can achieve this by means of automation rules.
I was able to add a default watcher by simply creating an automation rule at the event (trigger) of New Issue Created, followed by certain conditions which are called components in automation rule config. No Plugins are required to do so and we can choose this rules at global level or at project level as well. BTW the rules are very cool to do lot of stuff automatically.
HTH :)
