I have delete a project with the name "PROFI". When I try to create a new projekt with the same, it told me that there is allready a project with that name.
I think that deleted project is in the trash.
How I cam delete fully from the trash?
Where is the trash?
Thx
BR
Viktor
Adding to what Trudy and John has mentioned - if you login to Jira click on "." in your keyboard >> trash.
Under Trash do you see the "..." button if yes, click on it and select permanently delete as shown in the screenshot.
If you are not seeing what I have posted above - include a screenshot if what you see on your end.
Theodore
Hi Viktor - Welcome to the Atlassian Community!
Go to Settings > Projects
Then you will see Trash on the left side
Go there and do an immediate delete.
Hello @Viktor Braun
Welcome to the Atlassian community!
Refer to this article:
https://support.atlassian.com/jira-cloud-administration/docs/delete-a-project/
Hi Trudy,
thank you for the Information. Iknew that info. But in the sidebar I can't find "trash".
That is my problem.
Hello Viktor,
You may not be on the right page.
Click the gear icon next to your avatar in the upper right corner.
Select Projects.
That should take you to a page with this URL:
https://<yourBaseUrl>/jira/settings/projects/manage
If you are on that page and don't see the Trash option on the left, please post a screen image of what you see.
