Descomposition in n levels of projects and sub projects
javier manjon
July 17, 2016
This question is in reference to Atlassian Documentation: Classic plans
I would really appreciate it if you could give some kind of information about the possibilty to create a tree structure of projects in JIRA o any addon or pluggin. For example, I need to create a main program with n sub projects depending on the program and from this projects other level of projects and so, at least 10 levels from top to the bottom.
  Thank you very much in advance.
Niamh Williams November 29, 2016
I'm having the same problem!
