Hi All,
I know that Issue.GetProjectObject() , returns the project the issue relates to, but in create issue screen, the issue context is not null but I can not get the ProjectObject?
Im programming a control behavior and need to know at create stage what is the current project the create is for.
You can get the project id from ActionContext like this:
(String[]) ids = ActionContext.getParameters().get("pid"); String pid = ids[0];
And then use the id to get the project object.
done I have the ID, but how to get the project key ? the object it self?
ComponentManager().getInstance().getProjectManager().getProjectObj(Long Id); this will return the project.
You will have to cast your pid into long and pass as a parameter to the above method . You can refer the api docs .
Hi ,
Try the below code it might help
import org.ofbiz.core.entity.GenericValue import com.atlassian.jira.issue.Issue; GenericValue project = issue.getProject()
I have used this in one of my postfunction which works before the issue is created .
ProjectActionSupport projectSupport = new ProjectActionSupport();
Project currentProject = projectManager.getProjectObj(projectSupport.getSelectedProjectId());
System.out.println("The Name For Current Project: " + currentProject.getName());
The JiraWebActionSupport.java has a method called
getSelectedProjectObject()
So if your java program extends this action, simply call this method like
Project project = getSelectedProjectObject();
which will give you the last accessed project.
