Difference between 'Continue with Microsoft' and SAML SSO with Azure AD
mohithb
Now we can see that 'Continue with Microsoft' in the login page. Does it mean that we can login in using Microsoft credentials without have Atlassian Access subscription?
2 accepted
Ed Letifov _TechTime - New Zealand_
February 1, 2020
I believe this is correct.
This is just a convenient shortcut without the security features that come with Access i.e. no enforcement.
You may have to have the user created first in the system. There will be no sync e.g. for groups. You also have no control over who will actually be using Microsoft (and have controls enforced there e.g. 2FA) and who will be typing the same credentials (with a different password) into Atlassian form by hand.
mohithb
Veera
February 2, 2020
Hi @mohithb
The simple answer is 'yes'.
"Continue with Microsoft" is social login and it's optional. Users can choose this option or login normally using their email address and Atlassian account password.
With Access's SAML SSO, the users will be forced to use Azure AD credentials every time they try to login. It's not an option for the users.
mohithb
Thanks @Veera
Like Veera likes this
Veera
February 3, 2020
You are very welcome @mohithb
RobertD December 18, 2023
Similar question here...
We have Azure AD Access SSO enabled but our users mistakenly try to use the Sign in with Microsoft option instead of going to our custom login URL.  As an admin, I have not approved the consent request that is sent.
Question, what happens if I do approve the request consent?  Will they be able to login using  Sign in with MS and bypass Access or not be able to login? How does that login flow work?
