I'm using Xporter plugin to generate report.
I use the duedate field and custom field date.
When i generate the report, the duedate is in format dd-mmm-yyyy and custom field in format yyyy-mmm-dd. My advanced configuration seems to be ok on dd-mmm-yyyy.
Do yo know why there is a such difference of format between native date field and custom date field?
thanks in advance.
Hi Manu,
I don't know if you still need assistance with this, but there is a nice feature to address this problem. Check it out at http://jiraxporter.xpand-it.com/display/JIRAXPORTER/Working+with+Templates#WorkingwithTemplates-FormattingDateFields
You can know define your custom date format. Examples:
${dateformat(yyyy-MM-dd):CreatedDate}
${dateformat(EEE, MMM d, ''yy):CreatedDate}
${dateformat(EEE, d MMM yyyy HH:mm:ss Z):UpdatedDate}
