Different resolution for project
Michal Crkon July 1, 2013
Hi guys,
Is it able to create different resolution for project? I would like to create something like scheme but i do not see the option for it. End user wants to use specific resolution which will be applied only for his project. I do not want to add it to the resolution( resolution view - add new resolution) as in this case overy one of the projects has this in resolution option and if I do one exception every one of the projects will want to add their resolution till the resolution list will have 100 rows :-). Is any chance to use resolution only for one project? Thanks, Miso
We are currently using version 5.2.10
6 votes
RambanamP
July 1, 2013
you can use jira.field.resolution.include workflow properties at closed screen
check the following document
https://confluence.atlassian.com/display/JIRA/Workflow+Properties
jira.field.resolution.include 1,2,3,4 ( Resolution IDs that you want to include)
3 votes
J. Caldwell
July 1, 2013
There is, but it will take (potentially) a lot of work.
It is based off of workflow first off. It's a change to the properties of the transition when someone transitions it to one of the states that you want resolution to appear, you drill into that transition and use either a jira.field.resolution.include or jira.field.resolution.exclude value in the properties of the transition. You plug the numeric values of the transition into property value.
I say it can be a lot of work...because resolution is global. It doesn't have context of project or issue type that you can just associate with things. You'll need to manually do that (as described above). If you don't want that resolution to show up for everyone, you'll need to alter workflow appropriately.
Note...this doesn't stop someone from "editing" the issue and then choosing a value you don't want them to. The key there is to build the workflow so that folks can easily go through it to fix a resolution status.
Justin Alex Paramanandan
July 2, 2013
Agreed. Much like roles in JIRA, resolutions are global. Hence, it would be a bit tedious work to manually set resolutions for certain projects; but just like roles, it's worth the effort!
Bryan Trummer - ReleaseTEAM
Where are you locating the numeric values for the resolution IDs. I am using JIRA 4.1 with a soon upgrade to JIRA 6. I am just having some issue finding the numeric value of each resolution field.
allie ruby May 25, 2021
I found them as jira admin
  1. settings > Issues
  2. Scroll down to resolution (left panel)
  3. Click Edit of the resolution
  4. The URL has the 'id=#####'
J. Caldwell
September 11, 2013
You can either query the back end and get the values by looking at the resolution table, or in the app when you go to the Resolution screen under Admin and hover over the "edit" button, you'll see the ID in the string of the hover url.
Finally figured this out. Not as difficult as I was making.
