Display what step a comment has been made.
Diarmuid Campion June 23, 2014
Hi all, I'm extremely new to JIRA and I'm wondering is it possible to display at what stage a comment was made when progressing through the workflow. For example
Joe Bloggs added a comment 6 mins ago
In Progess (Step)
"This job is easy peazy"
crf
June 23, 2014
This information is not recorded directly in the comment's data, but it would conceivably be possible to reconstruct it from the issue's change history items for the status field. It wouldn't surprise me if somebody has built a plugin with that kind of functionality, so you might check in the Marketplace.
Nic Brough -Adaptavist-
June 23, 2014
Comments aren't tagged like that I'm afraid.
You'll need to find or write a bit of code that can look at a comment's date/time stamp and refer back to the history of changes to establish what the status was.
