Displaying limited tabs for jira issue status
SHANTANU SARDESAI April 11, 2019
I have multiple statuses (about 12) for a Jira issue type, But I just want to display tabs for most common status (6) when the issue is displayed and list remaining under "Workflow" tab. I have seen this but don't know how to specify which one to display as tabs and which under a a tab with is a drop down list box.
2 accepted
Gini Ingram April 11, 2019
You can control the order of the tabs using a transition property and entering opsbar-sequence in the key field, under 'Add New Property'. Type the property values so that the lower value with go to the top and higher values will go to the bottom.
David Laperle
April 11, 2019
