Distinguish between subtask created and issue linked
kumargaurav-tudip
March 26, 2020
Hi All,
For my project I have to use the webhook "issuelink_created". I need this webhook to be fired when a task is converted to a subtask in JIRA. The problem is, the webhook is also fired when a new subtask is created.
The response of webhook when the issue is linked is:
  "timestamp": 1585209380037,
  "webhookEvent": "issuelink_created",
  "issueLink": {
    "id": ***,
    "sourceIssueId": ***,
    "destinationIssueId": ***,
    "issueLinkType": {
      "id": ***,
      "name": "jira_subtask_link",
      "outwardName": "jira_subtask_outward",
      "inwardName": "jira_subtask_inward",
      "style": "jira_subtask",
      "isSubTaskLinkType": true,
      "isSystemLinkType": true
    "sequence": 6,
    "systemLink": true
 and the response when a new subtask is created is:
  "timestamp": 1585209275940,
  "issueLink": {
    "id": ***,
    "issueLinkType": {
      "id": ***,
    "sequence": 5,
    "systemLink": true
What does the 'Sequence' field specify? Can I use this field to distinguish? Any kind of help is appreciated.
Bill Sheboy
June 29, 2020
Hi @kumargaurav-tudip -- Welcome to the Atlassian community!
Did you figure out this issue yet?
From the automation rule perspective, I saw the same challenge that a Convert to... action cannot be accurately detected for changing to/from a sub-task as a trigger.  I created a defect for this issue for automation triggers.
Best regards,
