Hi experts,
I'm trying to implement project & request management process for a holding company. There're more than 100 companies and thousands of cost-centers. One of the requirements is to implement distribution of costs among various companies and cost-centers of the holding.
The main requirement is : for each issue, they want to select the companies and and cost-centers ( sometimes more than one cost-center for one company ) and provide a cost distribution percentage for each cost-center selected. Possible values for percentage can not be pre-defined, has to be an input field accepting any type of ( ##.## ) number values.
They basically want an "Add Another" button, select the company, select cost-centers and input the cost distribution percentage. If they press the "add another" button again, they will select another company and related cost-centers and percentages, etc...
Is there any way to implement this in JIRA?
is there any plugin providing this functionality?
Thank you in advance for your help,
Murat
P.S. : JIRA version : 6.3.15.
Basically you will only need Blitz-Actions (paid) and DBCF (free).
https://confluence.kepler-rominfo.com/display/KBA/Home
https://confluence.kepler-rominfo.com/pages/viewpage.action?pageId=4161561
Of course, you may need validation on the issue (i.e. sum == 100%) That can be done with JJUPIN, which has native support for the above, but you can use whatever.
Mostly you need write an own plugin that provides this functionality.
