Do DataCenter solutions are supported using container ?
Christian Miszczak March 12, 2018
We plan to use your DataCenter solution on some of your tools such as BitBucket, Jira and Confluence. In fact, CN has probably already some DataCenter licenses on such tools but used for other projects (Legacy and PTC).
We want to layout a new infrastructure based on containers for these tools, and I am wondering if we might encounter issues while setting up those for Dev, Staging and Production environments.
Do you support  DataCenter solution on containers ?
Is it possible to use external database, namely Oracle, for DataCenter solution using containers ?
Christian Miszczak
DevOps & Tools Specialist
CN / DevOps Platform
Matt Doar
Christian Miszczak March 14, 2018
Hi Matt,
Does Atlassian has a roadmap concerning supporting Jira on Docker ?
Does it makes sense to have dockerized Jira node in a Data Center model ?
Christian.
