i want to install our recent public version of our connect app on our Jira Cloud Test instance.
I have set up a token as explained here.
But i still get dont get a lic =active from the url passed to our panel.
Is it possible that this mechanism only works for private versions and quits working as soon as a version is published?
Is there another way to having a free addon installation of our own addon apart from setting up a private version that is identical to the public version?
Thanks in Advance
Jens
Atlassian says:
Please see this comment for an explanation as to why access tokens aren't working for you. To make access token work, please leave a comment on that issue with your hostname, and the Atlassian Connect engineering team will opt you into a feature flag which will enable a temporary workaround while we're working on a long term fix.
