Does anyone know if HubSpot Integration work with Jira On-Premise
https://ecosystem.hubspot.com/marketplace/apps/marketing/analytics-data/jira
Elements Connect will let you integrate HubSpot data into custom fields in Jira Server since HubSpot provides a REST API.
If you have any problems getting it set up, don't hesitate to contact the Elements Support team.
that integration is actually the Jira Cloud for CRM app which is Cloud only.
this is what I supposed.
As an alternative solution for me, do you know if a custom integration through APIs are available with Jira on-premise?
Thanks!
Besides the Atlassian app for Cloud, there isn't a real integration for HubSpot available.
Yes, but apart from HubSpot, can we use the Jira APIs on-premise?
