Hi Support,
We have already upgraded JIRA to 7.6.2 but We found that it didn't support plugins:Automatic Issue Security ,How long will it be release to compatible to the newest version(7.6.2)? Thank You.
Did you refer to Automatic Issue Security Add-on?
If so, this add-on isn't developer by Atlassian itself.
JIRA and other Atlassian products, allows you to request a compatibility upgrade to the vendor using the provided Button in the UPM (universal plugin manager).
Use this option or contact directly with the vendor for support.
Kind Regards.
