Does JIRA Datacentre trial license works on JIRAserver?
Megha Agrawal July 25, 2023
I am having one of my Jira running on Server which will be upgraded soon but before that we need to migrate some of the projects to other JIRA. And my Jira server is about to expire, will Jira server accept Jira datacenter trial license for 30 days?
2 accepted
Els Bassant
July 25, 2023
Hi @Megha Agrawal ,
Jira Server licences are perpetual, so your instance and plugins will keep working even if their license expires. The only thing that changes is that you will not be eligible for any support.
So if your only goal is to have the old data still accessible for migration that will work. But if the Server instance will need to be upgraded to Data Center later it is better to upgrade to Data Center licenses now.
Evgenii
Hi, @Megha Agrawal
Yes, you can use DC license for Server, but your Server Jira will beсome DC.
Evgenii
All your data will be available, you can use Jira while license is active.
Thank you so much for your prompt response !
Megha Agrawal August 2, 2023
Hi @Evgenii
Any idea, how many times can eval licenses be generated?
Evgenii
Hi, @Megha Agrawal
As far, as I know, 3 times (but I'm not sure)
ok, thanks
Thanks @Evgenii
My ultimate goal is to accesss my JIRA data after its license expires.
So if my JIRA becomes DC, then also I can use it for a month ?
Vedant Kulkarni_Trundl
July 26, 2023
@Megha Agrawal your Jira goes into READ-ONLY mode once the DC license expires. If you just want to access the data you can go with an expired version otherwise you need to apply for a trial/commercial license.
