×I know there is a Marketplace app called 'Easy Templates' but I was wondering if base Jira comes with any function for batch loading issues from a template and/or an Excel comma delimited file. I have a number of repeatable tasks that I would like to build in bulk.
Hi @Thayne Munson ,
you could use the CSV import : this way you can save your Excel file as CSV, and then import a batch of issues in Jira. The documentation will help you get the proper format : https://support.atlassian.com/jira-cloud-administration/docs/import-data-from-a-csv-file/
Let me know if this helps,
--Alexis
Very helpful. Thanks.
