Does Smart Checklist provide some way to assign specific checklist items to specific users?
Rahul Ganjoo July 18, 2018
I am looking for an option where I can assign specific checklist item to a specific user only. Taking a scenario in consideration where I need to provide access to "QA Complete" checklist item to a user who belongs to QA group whereas a developer should not see the option or the option is disabled.
Pavel Pavlovsky
July 18, 2018
Hi @Rahul Ganjoo,
With the Smart Checklist add-on you can highlight a specific person or group using "@" sign or date following by the instructions https://railsware.atlassian.net/wiki/spaces/CHK/pages/111843630/Highlight+person+or+date
Smart Checklist doesn't support person selection from the list (yet) and the task will not be locked to only this user. So everyone who has the Edit Issue permission will be able to mark item as completed.
Hope this helps.
Pavel Pavlovsky
Smart Checklist PdM
Hi @Pavel Pavlovsky _Railsware_,
Thanks for your reply. This clears it out. So, basically there is no way as of yet in Smart Checklist through which a specific Smart Checklist item can be restricted / allowed to a user.
The best that we can do is to mention a person's name in the checklist step and highlight it.
Hope my understanding is correct.
Pavel Pavlovsky
July 18, 2018
Yes, totally right.
Pavel
Thanks Pavel. I appreciate that.
Frank Gene McPeek
April 23, 2020
In 2018 you said "Smart Checklist doesn't support person selection from the list (yet)".  My question is that feature ready yet or is it still on hold?   Its the only feature that holds my organization from using it.
Frank
Pavel Pavlovsky
April 23, 2020
Hey, @Frank Gene McPeek
Please contact us at smartchecklist[at]railsware.com
Jack Hunter [HeroCoders]
@Frank Gene McPeek,
you can find this feature in Issue Checklist Pro and Issue Checklist Free
Here are the docs explaining how to use it: https://herocoders.atlassian.net/wiki/spaces/IC/pages/771620876/User+mentions
I hope it helps.
Jack
Like Frank Gene McPeek likes this
Frank Gene McPeek
April 24, 2020
In all of those products you can list a person on the checklist as being responsible, but there are no notification sent.  "Currently, unlike in Jira, no notifications are sent to the user who was mentioned - this includes email notification."  We are looking to be able to use a smart checklist to be able to assign subtasks to others and have them notified.
Frank
Like Martin Schuster likes this
@Frank Gene McPeek,
Email notifications are already available in the Issue Checklist
https://herocoders.atlassian.net/wiki/spaces/IC/pages/1985118347/Email+notifications+for+user+mentions
So, when the user is mentioned/assigned, they can get an email exactly in the same way as they get the email when mentioned in Jira's comments.
That feature is disabled by default and can be enabled by Jira admins.
Like simon democko likes this
Yogesh Mude
July 18, 2018
HI @Rahul Ganjoo
Welcome to the community!
If i have understood correctly and the issues in "QA complete" status that you want to see user which belongs to QA group only then you can use the workflow properties ie jira.permission.*.
Please have a look at the below KB.
https://confluence.atlassian.com/adminjiraserver073/workflow-properties-861253674.html
Hi @Yogesh Mude,
Thanks for your prompt reply. Your answer points to a workflow property through which I can manage access to certain transitions in the workflow itself. But, I am looking for a way through which I can manage access on Smart Checklist add-on items. In other words, I want to know if there is a provision in Smart Checklist through which I can restrict certain users from accessing specific Items in the checklist. Kindly suggest.
