We are using Jira Cloud. Now we would like to add a Jira tool to create test plan to migrate from testlink to this tool.
You would be better to have some options to take the best.
Hello @miguel.valle
I can recommend our QAlity Plus - Test Management for Jira. It allows you to create test cases, test plans, allows reporting, reporting and linking defects to executed tests and more.
Alternatively, you can also try QAlity - Test Management for Jira that is free of charge. You can view a comparison of those two to see if it's sufficient for you.
Best regards,
Sebastian
I think that you also might be interested in those two positions:
@Jarosław Solecki [Deviniti] For TestFLO, how can I add it to Jira cloud? when I search for this app in the Jira's APPs it cannot find it. I think this is a good option to migrate from Testlink.
@miguel.valle Sorry I didn't notice that you are using Jira Cloud. TestFLO is unfortunately available only for Server and DC.
Hi @miguel.valle ,
You can give AIO Tests - Test Management for Jira also a try.
We are one of the few test management tools that do not treat test entities like cases, executions, cycles, runs, etc. as Jira issues. This approach helps us provide a more seamless and intuitive way of test management.
Key features of the app are
Here is a link to our documentation -
https://aioreports.atlassian.net/wiki/spaces/ATDoc/overview
If you would like a demo, you can book it at your convenience by clicking here or you can reach out to us via our support portal.
AIO Tests Support
The other option is Zephyr: https://marketplace.atlassian.com/apps/1014681/zephyr-squad-test-management-for-jira?hosting=cloud&tab=overview
Both Xray and Zephyr are great tools, but I would recommend Xray. Differences: https://www.getxray.app/xray-vs-zephyr/
Hi @miguel.valle welcome
I use Xray Test Management for test cases, and really get on well with it. Likewise for others in my team. I'd recommend including this in the list of tools you explore :)
