If I have a project named "My DOGS" with key DOGS and I change it to "My CATS" and the key becomes CATS, would my existing issues with names like DOGS-1, DOGS-2, DOGS-3, etc, be renamed to CATS-1, CATS-2, CATS-3, etc?
Thank you.
Hi @Mylah De La Rosa ,
Welcome to the community.
Yes, it will also change the key of the issues. But the issues will still be available with their old key. So if you search for DOGS-1, it will still work.
Thank you, Bastian.
