×I have a few questions about the issue numbers.
First, I use them for easy searching and when communicating with coworkers to easily know what issue I'm talking about.
So:
1. Do issue numbers have other uses and purposes?
2. Can I delete issues (that don't contain data) without it damaging anything? - maybe I can use them for any kind of data, or just it's more comfortable to have three-digit numbers than four-digit ones
3. Does Jira have issue number limits?
Thank you in advance!
Hello @salome gogolauri
To answer questions:
1. This depends on your company and how much of issues does it need to have, from Jira side, there are no limitations when it comes to number of issues
2. You can delete issues if you have permissions for this - permissions are based on project roles, groups and individual users
3. Jira doesn't have issue numbers, however you can set the limitation of issues on a board:
