Does anyone have experience with the Neat Boards add-on from Technerium? The documentation specifically mentions Sprint boards, but I'd like to know if it works with Kanban boards before I submit an internal request for approval to use it.
Hi Mady, assuming you have the add-on it should work by Sprint boards. I would recommend trying a 30 free trial first to see if it is what you're after. Thanks Habib
