×My company will be phasing out of Teamtrack soon and moving ahead with JIRA. However after research it seems that there is no eloquent way to transfer all of our data from Teamtrack to JIRA. I've seen some post almost a year old with some heavy scripting required and not great details. I was hoping someone might be able to point me in the right direction on the best way to get this achieved.
Thanks again,
Patrick
We migrated a few years ago - very happy now :). We did a few things you can consider:
Yea I looked into the JIRA Command Line Interface a bit from one of your previous post. I'll have to take a closer look to attempt to fully understand it. We are planning on moving over ALL previous issues.
Is there any way you could provide insight on what exact scripts you ran inside the JIRA Command Line Interface? Was it all of them or only select ones you deemed appropriate?
The primary actions you use for this are:
Depending on how automated you want to be, you may use createProject and similar project configuration actions. If users are a problem, you need the user actions. You will need to test with many runs, start with a small subset to iron out the wrinkles. You might want to consider an Atlassian Expert to help you through this.
