'Diagram' mode for editing Workflows doesn't work.
STR:
1) Click 'edit' workflow (it does not matter active workflow or not).
2) Switch to DIAGRAM mode.
ACT: Diagram interface does not appear.
EXP: Diagram interface should work.
NOTE:
It's happened after last Jira upgrade,
and NOT connected with the absence flash plugin and incorrect browsers work.
I have the latest Flash Plugin version and tested with all browsers and on the several PCs.
Same issue.
Jira v5.1.7
Flash 11.7.700.169
All lastest browsers
/s/en_USnk2p2x/786/5/_/download/resources/com.atlassian.jira.plugins.jira-workflow-designer:workflowdesignerflex/flex/jira-workflow-designer-flex-2.6.13.swf
Response body: 0 bytes
[Full size image]
hi maxim
can you take a look at the webservers logfile?
grep for something like
plugins/servlet/jwd/amf/
lets check the errorcode the apaches shows
