Hi! I changed groups, permission scheme and now my developers and users don't see project which only they have to see. Please, assist
Look at the project permission scheme and make sure that the required developers and users are granted the Browse Issues permission.
Ok. In what interface this project is not visible?
Also try to use permission helper to check if a user have permissions for an issue in this project. You can find permission helper in System -> Permission helper.
Used perm helper: Status: does not have the 'Browse Projects' permission
But this guy added to the group,which have role Users, Developers, this two roles Browes Project:
So you need to check the whole chain:
The permission helper is telling you that at least one of those is missing
Hmm. Those two look good.
Can you show us one of the users with their group (with personal ids scribbled out if you want - we're only interested in memberships), i.e. that they can log in, they're not deactivated and they're in one (or both) of jira-it or jira-head-departments.
@Gulnoza Davlatova in what interface of Jira these users can not see the mentioned project?
in lists of projects in our JIRA, when they search, can not find and view
I have no idea so far. But something is wrong :) You've checked everything and it should work.
Thanks,Alexey!Should but.... My group does not accept the role (user, developers). I think and I dont know why.....
According to the screenshot that you provide it seems like you added the user jira-it to the development role.
I believe you intended to add the group jira-it to your roles.
Hi!
I added groups before and it work problem was that my groups dont accept roles. Thanks.
