Downgrade zephyr for jira
VistaJet IT August 20, 2014
We have Jira running on version 5.1.7 and we installed Zephyr for Jira v2.5.1.25101747.
The plugin is not working on the jira version that we have, so we would like to downgrade. What is the best way to do it?
Thanks and regards,
Sirach
Alexey_Rjeutski__Polontech_
August 20, 2014
If you haven't done anything valuable with it - uninstall plugin and install the proper version from the marketplace.
The problem is that we have been using it for six months now, so we would need to downgrade the plugin.
Thanks.
August 20, 2014
I suppose it would be better to contact their support then
No, we have been using it for six months now, so we would need to downgrade the plugin.
Thanks.
