Due is EMPTY does not return all such issues
Kristján Geir Mathiesen
Hi good folk.
I´m searching for certain types of issues, some of them have Due Date other don´t. So I basically have the same search twice, joined with an OR. First part has a certain due date criteria and the latter part is:
assignee is EMPTY AND category not in (abc, def) AND due is EMPTY
However, when I look only at this latter part, it returns 10 issues.
If I take out "AND due is EMPTY" and run it that way (assignee is EMPTY AND category not in (abc, def)), then I get 20 issues. But only 3 of those 20 issues have a Due Date.
In other words, this latter half is only returning 10 out of 17 issues it should return:
Any ideas?
Running on Jira Software 8.2.5
Thanks, KGM
Bueller Bueller Bueller - YouTube   -  anyone?  :)
Anyone feeling creative regarding my question on this Saturday?
Thanks @Bogdan Gorka for your time and idea. Good to know that I am not totally loosing it... :)
I did re-index one of the projects, that those 7 ticktets belonged to, but to no avail. Still doesn´t show up in the query.
Anyone else got an idea?
KGM
Bogdan Gorka
November 14, 2019
I did a little research and it is hard to tell.
The field 'due' has an alias 'duedate' so it can't be the reason that you are using the wrong field (More: https://confluence.atlassian.com/jirasoftwareserver/advanced-searching-fields-reference-939938743.html#Advancedsearching-fieldsreference-DueDueDatedueDateDue)
The keyword EMPTY and NULL can be used interchangeably with the 'due' field so it can't be the reason either (More: https://confluence.atlassian.com/jirasoftwareserver/advanced-searching-keywords-reference-939938744.html)
If the JQL itself is not likely to be a reason, I would re-index all the projects in categories not in(abc, def) and try again with the query.
