×Duplicate issues created when using components. I am using automation and using 3 components and I am getting duplicate issues. How can I combined them all into one issue? How can fix this? It used to not do this previously.
So it is creating 3 sub-tasks?
Do you have other automations firing that might be cloning or creating the sub-tasks?
One way to check is to execute the rule and then go to the global automation audit log to see which rules actually fired.
No, it shouldn't be creating them in the first place. You can turn it on, but it is not solving the problem. Do you do what I suggested above?
Did you look at the audit log to see if there was more than one rule firing at that time that could have created the extra issues?
you probably just need to open a support ticket with Atlassian.
https://support.atlassian.com/contact/#/
Please post back here with the resolution so future readers and see.
