×Does anyone know how to edit a system filter (My open issues default filter that shows under Issues). There appears to be two concepts of 'My Open Issues'. One is a system filter as found in that issues menu and the other is a default, but sharable/editable filter. I cannot find a way to edit the system filter and it is returning an error because the 'resolution' concept has been removed from our fields. I need a way to edit the system filter so it no longer looks at the resolution field, but the status field. Any help is appreciated.
More Detail:
I am agreeing with GeorgeCC, I am looking for a way to change this globablly, but my larger issue is I cannot change it at the user level for the system filter.
Here are some screenshots to help.
So, on the screen you can see two filters for My Open issues. The highlighted top one is the system filter. The bottom one is the one that shows up when I search for filters which I can edit.
http://img35.imageshack.us/img35/3509/issuesfiltersselection.png
And, the when I select that system filter, I get the following error because the resolution field is hidden from all users. You can see on this filter I have no cog to edit it.
http://imageshack.us/a/img841/7929/issuesfilterserror.png
These results are from the 'my open issues' links under favorites (outlined in screenshot) which loads properly because it doesn't reference the resolution field. This one can be edited unlike the system filter.
http://img560.imageshack.us/img560/337/favoritefiltersmyopenis.png
Back to the original question, how I can edit the system filter? Thanks!
Are you serious?
Why in the name of heaven and hell it is not possible to either
a) modify a filter and just click "save" and link that saved version to the logged in user
or
b) give admins a way to edit the default filters
JIRA is very good tool with great capabilities but these oddities make it really hard to love.
(I would also accept if it was necessary to update the DB directly for once ...)
You can't edit a built-in filter, which is hard-coded, but you can trick your HTML. When you click "my open issues", you will be redirected to a custom filter of your choice.
First of all, create a custom filter, share it with everyone and write down its ID, e.g. 10454.
Then paste this code as announcement banner at /secure/admin/EditAnnouncementBanner!default.jspa:
<style> #announcement-banner { padding: 0 !important; border: none !important; } </style> <script> var filterId = 'CUSTOM FILTER ID HERE'; AJS.$(function() { var replaceUrl = function(link) { var $link = AJS.$(link); var url = $link.attr('href'); if (typeof url !== 'undefined') { var newUrl = url.replace('filter=-1', 'filter=' + filterId); $link.attr('href', newUrl); } }; var selector = '#find_link-content a[data-filter-id="-1"], a.filter-link[data-id="-1"]'; AJS.$(document).on('mouseover', selector, function() { replaceUrl(this); }); AJS.$(document).on('click', selector, function() { document.location.href = AJS.$(this).attr('href'); return false; }); }); </script>
For programmers: this replaces all occurrences of links matching the given selector. There may be other places where a link to the built-in filter appears, and my hack doesn't work. If you find such place, share your selector and I will include it.
Thanks this did the trick for me. I replaced the "Reported By Me" Filter
Can you tell exactly how it worked for you?
I tried the same and it's not working, and i really need this
EDIT:
This changed the "my open issues" filter, from the "issues" menu in the main Jira navigator.
I thought it will replace it in the "issues" panel on the left when you go in to the project page.
Is there a way to do it? @Damian Nowak3
Hi @Nir Haimov i just used the script to replace my "reported by me" filter
For this issue. I created a new filter and get the id of it. And put into the script
Then i changed replace code for filter id "-2"
Then i added the script to admin panel > system > user interface >Announcement Banner
This changed both. Top menu and the left menu
Left menu
Top menu
Here is the final code
<style>
</style>
<script>
var filterId = '13209';
AJS.$(function() {
var newUrl = url.replace('filter=-2', 'filter=' + filterId);
var selector = '#find_link-content a[data-filter-id="-2"], a.filter-link[data-id="-2"]';
replaceUrl(this);
return false;
</script>
Please note that there is two lines to replace
Hope this helps.
Hi @Ozan Bayram
I wanted to change the default filter inside the "issues" menu inside the project (see attached)
Couldn't find a way to do it... any suggestions?
When i clicked that link it navigates to a link like this "?filter=myopenissues"
Maybe you could give a try to replace that one
but i dont think this is possible
Yeah,
It's not possible, though you came up with a way to accomplish that
Thanks any way :)
@Damian Nowak3@Ozan Bayramis there a way to extend this workaround to the Switch filter dropdown menu?
don't know but maybe same solution can be applied. Basically you need to find what do you want replace and change the script
Thank you Ozan.
Actually I don't know where to search for the tags I need. Is there any documentation or something like that to search for them?
Hi Everyone,
I have opened a feature request for this: https://jira.atlassian.com/browse/JRA-63317 - please take time to vote and add your comments to this issue.
Keri Hannon | Atlassian Support
Oh Jenae Leahy, please do not hide the resolution field in JIRA. Many things depend on that and I would really prefer to leave it untouched. What is the issue you are facing if you have it enabled.
And the system filter, it is not editable, I am guessing it is not in any database table, it is in code - https://answers.atlassian.com/questions/125565/how-can-i-change-the-my-open-issues-filter</span<>>
Renjith, thank you for your reply. Sorry for the tardiness of mine, it has been a busy month. We prefer to hide the resolution field because it hads an extra step for the users for how they utilize JIRA. They must not only close it, but fill in a form related to resolution. For our uses, this is an uncessary step and just takes time. If I could set one resolution option and have it automatically assigned when clicking our closed status, that would be fine. Is there a way to do that?
Hi Jenae,
Install JIRA Suite Utilities and then you can add Update Issue Field as post function. Select Resolution and add it as Post Funtion.
BTW, I still need to change system default filters same reason you had. It appears I can't.
Same as what Tansu said, but it does not require any plugin. JIRA itself has the option to Update Resolution during a transition in the post-function and you can avoid the extra step being done by users. So in whichever worflow transition you think that the issue is actually resolved, just set that value to any pre-fixed resolution field in the post function.
Thanks Domian Nowak, its pretty good script. but i need When i click "Assigned To Me", in Project Issues Panel Pre filter selection it redirected me to a custom filter of my choice.
Hi Jenae,
Edit: Oh, I missed OnDemand tag. I'm not sure this works for OnDemand
Does anyone have any idea here. I am pretty sure I laid out the problem pretty clearly in my comment below, but I will update the main post. Help!
I don't see how this changes the behavior of the system filter, "My Open Issues," for everyone.
The filter must be shared to everone. Otherwise the link stays the same
Greetings,
I extracted the following information from https://confluence.atlassian.com/pages/viewpage.action?pageId=185729481
System filters (My Open Issues, Reported by Me, Recently Viewed, All Issues) and your favourite filters are shown in the issue navigator. You can also find and run issue filters via the 'Manage Filters' page (see Managing your filters section below).
To perform a saved search in the issue navigator:
Let me know if there are any questions.
Jason | Atlassian
