Edit field for Linked issue simultaneously
Deleted user April 25, 2023
I am trying to sync the Sprint value for linked issue. However, it doesn't  work by the automation. Does anyone know is there anything wrong on my script ?
The Scope setting is All projects.
Following is the steps
  1. Step 1: Create task on Project A, Project B, Project C respectively
  2. Step 2: Linked Project B-Task and Project C-Task to Project A-Task
  3. Edit  Sprint field on Project A-Task
  4. Check Project B-Task and Project C-Task and found the Sprint value is not same as Project A-Task
Ashish Bijlwan
April 25, 2023
Hi @[deleted]
Please try below Automation rule setup:
Hope this help you!
Thank you,
Ashish
Deleted user May 8, 2023
Hi @Ashish Bijlwan
It's worked.
Thank you for your input !!
Ashish Bijlwan
May 9, 2023
Hi @[deleted]
Glad to hear that.
Thank you,
Ashish
