Edit issue screens customisable by transition ?
Pilar
September 7, 2015
Hi
I have a checkbox type custom field say ABC
I want to make the custom field visible (and therefore editable) via edit button when the status is in Progress  but NOT visible (and therefore not editable) on edit issue screen when issue is in Open.
As i understand the edit issue screen is defined in the screen scheme and there is no way to customise it by transition. But what are my options here?
Is it possible?
Deleted user September 7, 2015
A few add-on's can offer this features, so that is your best option. Search the marketplace for Custom Field plugins (there are many  to choose from).
You can also create a javascript on the page and do what you like, I know a few teams who do it this way. Javascripts can be inserted in any JIRA page or in the JIRA Custom Field description.
Christian Czaia _Decadis AG_
September 8, 2015
Hi Gabriella. JS in field descriptions is not working in current JIRA versions so I would advise against it. Cheers
Deleted user September 8, 2015
Agreed. I am against it too.
Rodrigo Rosa
September 7, 2015
Hello Pilar,
Please check this previous answer to get more details about that.
Rodrigo Rosa
