Enabling Jira for HTTPS with self signed certificate
Roger Spraggon
April 28, 2020
I followed the instructions in https://confluence.atlassian.com/adminjiraserver085/running-jira-applications-over-ssl-or-https-981155619.html (for self signed certificate) however when I try to access Jira after enabling either "HTTP and HTTPS" or "HTTPS only" I get "https://xxxxxxx.domain.local:8443/secure/errors.jsp" and "Jira access problem" with a blank screen. I'm also still getting a certificate error, not sure if this should go away if changes have been done correctly or if there is something that I've missed
I have tried to modify the home URL page to match the https and port 8443 before restarting the Atlassian service but this doesn't make any difference.
I've looked at the log files and I'm not seeing anything that stands out though I'm not 100% sure which log file to look at and what to look for.
Gonchik Tsymzhitov
Hi!
I'd recommend you try to make call using
curl -vvv https://xxxxxxx.domain.local:8443
As a result you can see what exactly broken in certificate.
Roger Spraggon
April 28, 2020
This is the result from curl:
curl -vvv https://xxxxx.domain.local:8443
* Trying ::1:8443...
* Connected to xxxxx.domain.local (::1) port 8443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: C:\Users\Public\Downloads\curl-7.69.1-win64-mingw\bin\curl-ca-bundle.crt
CApath: none
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (OUT), TLS alert, unknown CA (560):
* SSL certificate problem: self signed certificate
* Closing connection 0
curl: (60) SSL certificate problem: self signed certificate
More details here: https://curl.haxx.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
