Hello!
I tried to follow the document to enable the public sign up:
https://confluence.atlassian.com/adminjiraserver/enabling-public-signup-and-captcha-938847032.html
For the step "In the 'Mode' drop-down, select 'Public'." This field is not on the configuration page at all.
My version of Jira should be: 1001.0.0-SNAPSHOT
Any global setting I need to set in order to see the public sign up setting? Or if my version does not support such function?
Thanks a bunch!
Hi @Pui Yan Lee ,
On the top right corner of the document page, click on Cloud. I think it's a bit different than server.
also take a look at this page:
https://confluence.atlassian.com/jirakb/public-signup-setting-is-missing-777026981.html
Hi @Parvaneh Zand , thanks for the reply!
I did some digging that I have also came to the same conclusion. However, how could I determine that my Jira cloud/service as agent based priced licensed or not?
What is your JSD version?
It seems that in earlier vresions, there's no limitation for service desk users and a user who has no application access is also considered a customer.
