Enabling Smart Commits - Security Note Clarification
Leon Degiorgio
March 8, 2022
Hi all,
I would like to get some clarifications on the small security note mentioned in the "Enable Smart Commits" documentation.
A small security note
Elevated access rights in Jira products can result from the way that Git (and Mercurial) allow commits to be attributed to a user other than the user pushing a change to the repository.
If this seems like a risk for your situation, then you should consider disabling Smart Commits in your Jira site.
Can someone please elaborate a bit further on what might be impacted or a particular scenario where or how this might occur?
Fabrizio Catalucci
January 15, 2025
I think the explanation could be like this.
It is easy to "spoof" the email address of the author of a Git commit: a malicious user could get his commits to be attributed to another user in Jira, in order to trigger workflow transitions with elevated privileges.
