Hi everyone.
When i create an issue type (Epic) - Epic link field is not editable which is ok, i replaced it with Epic color and Epic status fields.
The problem is: for the rest of issue types (Bug, Task, Test, etc.) after this edit the Epic link field for this issue types is not editable in creation/ edit mode. So if put the Epic link field back to these issue types to can edit it, the Epic color & Epic status fields from the Epic issue disappear and if i put these field back all this process is going to repeat.
Do you have any idea why?!
Raul
With your question you gave me an idea.
I changed the configuration fields for the project but wasn't in the default scheme which is assigned for the project.
Thanks a lot man,
have a good day!
Raul
Hi Raul,
When you mention that you are putting these fields in these screens, are you messing with the project screen scheme? Could you double check if they are being properly configured in the edit/view screen for that project?
