I am trying to show Epics w/ their Stories across all Projects. Since I can't get the Story to group under epics when showing all projects, I'm showing all Epics as swimlanes and their stories underneath. If I can show the Epic's Issue Key and Status, then it will be easier to identify which project they belong to. I can do this with Sub-tasks under any issue, but not stories under epics. Is their a JQL I can use to create swimlanes?
+1,
having Epic swimlanes display aligned on Story swimlanes (Status + key + link to the ticket) would be really helpful !
