Epics no longer showing issues in epic for jira issue view
Brian Seale
August 19, 2014
Two days ago Atlassian upgraded our jira instance to
Version 6.4-OD-03-010
Build Number64001
Since then all of the epics we typically view in jira no longer show the issues in the epic. The list has gone missing. I've tried re indexing and finding if the specific screen has been removed with no luck.
can anyone help?
Mehmet Kazgan
August 19, 2014
And I think it might be related to the issues they fixed in that release:
https://jira.atlassian.com/browse/GHS-10890?jql=project%20%3D%20GHS%20AND%20fixVersion%20%3D%206.4.4
I would contact Support.
Dave
August 20, 2014
It sounds like you're running up against this bug -https://jira.atlassian.com/browse/GHS-11065
I would recommend watching that for any updates on the progress, as well as voting/commenting to provide feedback to the dev team.
Mehmet Kazgan
August 19, 2014
Any schemes changed recently?
Brian Seale
August 19, 2014
None that I can find in audit. My primary suspect is the on demand update.
