Hello, we have the following problem on our instance : When we create a project with the default value, and then try to administer it, we get the following error :
Cause:
java.lang.NullPointerException
Trace d'empilement: hide
at com.atlassian.jira.projectconfig.contextproviders.ScreensSummaryPanelContextProvider$SimpleIssueTypeScreenScheme.<init>(ScreensSummaryPanelContextProvider.java:217)
at com.atlassian.jira.projectconfig.contextproviders.ScreensSummaryPanelContextProvider.getContextMap(ScreensSummaryPanelContextProvider.java:59)
at com.atlassian.jira.plugin.webfragment.CacheableContextProviderDecorator.initContextMap(CacheableContextProviderDecorator.java:70)
at com.atlassian.jira.plugin.webfragment.CacheableContextProviderDecorator.getContextMap(CacheableContextProviderDecorator.java:46)
at com.atlassian.plugin.web.model.AbstractWebItem.getContextMap(AbstractWebItem.java:30)
at com.atlassian.plugin.web.model.DefaultWebLabel.getDisplayableLabel(DefaultWebLabel.java:55)
at com.atlassian.jira.projectconfig.contextproviders.SummaryContextProvider.getPanelFromDescriptor(SummaryContextProvider.java:129)
at com.atlassian.jira.projectconfig.contextproviders.SummaryContextProvider.getPanels(SummaryContextProvider.java:114)
at com.atlassian.jira.projectconfig.contextproviders.SummaryContextProvider.getContextMap(SummaryContextProvider.java:92)
at com.atlassian.plugin.web.descriptors.DefaultWebPanelModuleDescriptor$ContextAwareWebPanel.getHtml(DefaultWebPanelModuleDescriptor.java:141)
at com.atlassian.jira.projectconfig.tab.WebPanelTab.getTab(WebPanelTab.java:75)
at com.atlassian.jira.projectconfig.servlet.PanelServlet.outputTab(PanelServlet.java:163)
at com.atlassian.jira.projectconfig.servlet.PanelServlet.doGet(PanelServlet.java:136)
Thanks if you can help.
Stéphane
Is seems we had a corrupted project. I suppressed a couple of unused projects, and now the problem disappeared...
Thanks Andreyev,
I've used the integrity checker, but it tells me that my config is OK.
