Error about component when importing issue from CSV
Jason Liu
The component is existing and when we import issue from CSV, it always show the error:
The component xxx doesn't exist in this project and can't be added. Does anyone know why it happens?
Craig Nodwell
Hi @Jason Liu have you reviewed the logs?  What do they say on the import?  There should be further details in there.
Jason Liu
Hi Craig, Component issue has been solved. I just found another one. Please see the error: The value [ {null=UK-ITEC Connect (Xerox)} ] can't be added to the Custom Field [ Partner Name ]. The value [ {null=UK-ITEC Connect (Xerox)} ] can't be found or is in the incorrect format.
I checked the CSV and there's nothing before UK. I'm so confused. Do you have any idea?
Jason Liu
Hi Craig, I just found that there's format problem in the CSV. Problem solved. Thank you.
Like Craig Nodwell likes this
RISHAV KUMAR GUPTA
June 24, 2022
Hi @Jason Liu ,
The component field should be there in the target project while importing .When you map with the field values of component from one project make sure that the component field should present in target project when you are mapping otherwise it will throw a error .
For checking purpose you can see in target project whether components is a custom field or system field . A/Q to it you should map.
I hope , I have cleared your query. let me know if you are facing some issue with screenshot.
Thanks & Regards,
Rishav Kumar Gupta
Jason Liu
Hi, Kumar, Component issue has been solved. I just found another one. Please see the error: The value [ {null=UK-ITEC Connect (Xerox)} ] can't be added to the Custom Field [ Partner Name ]. The value [ {null=UK-ITEC Connect (Xerox)} ] can't be found or is in the incorrect format.
Jason Liu
Hi Kumar, I just found that there's format problem in the CSV. Problem solved. Thank you.
SERVER
VERSION
8.5.2
