Hi all
I found some error between conecting Jira and Bitbucket
our jira version is Jira v8.2.3 and Bitbucket version is v5.12.0 both of application using https potocal
What errors are you seeing?
The logs can be helpful for debugging these connections. Also check out this document from Atlassian about troubleshooting this connection:
https://confluence.atlassian.com/bitbucketserverkb/troubleshooting-jira-integration-779171834.html
