I've got this message while trying to install JIRA using mysql 5.7
I have just seen in the release notes that mysql 5.7 is not supported by JIRA, Is it planned to support it at some point or to have a manual way to fix it as you have for confluence ?
Thanks.
Hi Vincent!
Use MySQL 5.6 or older. This is the only solution for now. Remember about odbc driver. Place it in lib folder of JIRA.
Michal
thanks
Earning the Mindful Member badge proves you know how to lead with kindness, plus it enters you into a giveaway for exclusive Atlassian swag. Take the quiz, grab the badge, and comment on our announcement article to spread the good vibes!
Start here
