Error importing Project
Johnathan Smith May 27, 2015
I am trying to import a project from the cloud JIRA to my firms local JIRA.  This is the first time we are doing this and I am new to JIRA..
I do a backup of the cloud JIRA and then I try to do a import of the project and I get the following Errorss
Errors The data mappings have produced errors, you can not import this project until all errors have been resolved. See below for details. Custom Field Configuration The custom field 'Epic Colour' of type 'Color of Epic' is required for the import but does not exist in the current JIRA instance.... but I dont see any type "Color of Epic" please help
I am new to being a JIRA Admin so I dont know what the issue is.. can someone please give me details on this.. thanks
Benito Picarelli
May 28, 2015
Hi John,
Have you attempted to simply create the Custom Field to check if the import will proceed?
Johnathan Smith May 29, 2015
yes... the issues is that I cant map it to type 'Color of Epic' so the import dont work
Nic Brough -Adaptavist-
May 27, 2015
That field is an Agile field - do you have Agile installed in the target JIRA?  And do you have the epic colour field in the list of custom fields?
I have Agile installed and I cant create the field "epic colour" due to know having the type 'Color of Epic'
May 27, 2015
You must have a very old version of Agile installed, which suggests you are trying to import a new version of JIRA into an older one that does not support it. You need to decide how to migrate your data - either a new custom field to hold the colour (which isn't going to be of much use because it will be text), or look at the version of Agile you're using and bring it up to a version that does implement the colour field.
we just installed Agile and its version 6.7.2 which is the new version.. it is updated
